hard reset sony ericson experia x10i
master code for sony ericson xperia x10i
Hello,
Best of my knowledge, you won't be able to find master code for Sony E X play, but you can try below steps to reset your phone to factory default.
Option 1 – Hard reset Xperia X10 using hardware buttons
1. Unlock the screen then press and hold the Power button for two seconds. Select the Power off option. If the phone won’t turn off, pull and replace the battery.
2. Hold the Left and Right buttons located under the display.
3. Press and release the Power button while continuing to hold the Left and Right buttons until instructions appear.
4. Follow the instructions on the screen.
Option 2 – Hard reset Xperia X10 using software
1. From the Home screen press Menu and select Settings, or tap the application slider and select Settings.
2. Select Privacy.
3. Tap Factory data reset.
4. Select Reset phone.
5. Select Yes to confirm the hard reset.
The Sony Ericsson Xperia X10 will then go through the process of formatting the memory. Wait for it to restart and factory default settings will be restored.
这个答案有帮助吗?
please resetting my Sony Ericsson x10i with the two action bottons under the sreen and power botton is not working. Please is there any other way to hard reset my device.Help me please.
Am facing the same problem how can i get your assistance
sure. how may i help you?
Guys if you are suffering over the same problem please try a technician just because i have triede several times but all the options has failed.
这个答案有帮助吗?
yes its true some sony not support hard reset
my phone is not support to hard reset
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 31,513
4条评论
Hloo guys I forgot my secret answer Wat can I do pliz help me
由 Nsubuga Maraim 完成的
das funktioniert nicht
由 Emil Schlampp 完成的
Yes me be master code need
由 MD. Kamrul Hasan 完成的
me lo regalarom con átron
由 fernanda lujano 完成的
