跳转到主内容
加入维修社区 - 创建账户
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Loudspeakers problem on call
I have a problem with my loud speaker.
When I call people and talk through the phone speakers everything is good but when I switch to loud speakers, nobody can hear me and all they hear is loud noise not even close to person's talk.
I also tried to check the loud speaker and when I record an audio the sound is clear and it records my voice clearly.
what might be the problem?
Update (09/23/2015)
I just checked another thing.
the loud speaker option works fine on whatsapp call, which means the problem exist only in cellular phone calls.
plz help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hello Tsviel Zaikman ,
If you use phone pouch flip cover or cosmic protector just remove it and try again. galaxy S5 having special Noise reduction system using audio focusing technique and it is not limited to one mic such as a ordinary phone.
这个答案有帮助吗?
得分 1
9条评论:
I have removed the phone protector case but yet it doesn't work/
完成的
Go to Setting > Sound > Call > check off the Noise Reduction
完成的
its checked off already
完成的
Could you switch the phone to GSM mode and try. This kind of issue i have experienced in HD voice enabled network operators.
完成的
the phone is on wcdma/gsm mode auto select but if i switch to gsm only i lose connection to the 3g and the cellular network
完成的
显示更多的4条评论
添加一条评论
Hello. Did you solve this issue? I have the same problem with the loudspeaker noise during cellular, Watsapp and Viber calls. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tsviel Zaikman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 2,873
