跳转到主内容
加入维修社区 - 创建账户
佳能摄像机修理和支持指南
The 'double memory card slot cover is missing, what can I do?
I have a Canon XA10 HD Camcorder, and I have lost the 'double memory card slot cover' that protects the memory card holders. Its just a clear plastic cover, and it doesn't seem very important, but the camcorder doesn't work without it!
Can I buy a replacement somewhere? or is there a way to make the camcorder work without the slot cover?
Thanks for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Don't know if there is a way to make it work without, but there are two, very small, lever switch sensors on the sliding door tray that tell the camera that the door is open or closed. If you can't find a proper door to replace with, you may be able to find a way to mimic the closed door by adding a dot of hot glue or tape or something to keep them in the closed position.
You'll need to take the camera apart to reach the sensors. Start with the bottom plate, then the right side, then top, then left side where the sliding door tray is located.
Hope that helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
suziegow 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 20
总计 645
