跳转到主内容
中兴手机维修指南
20 个问题 查看全部
pop up that says google search has stopped
I have a ZTE majesty i keep getting a pop up that says Unfortunately, google search has stopped. Now I have now keyboard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 86
4条评论
That worked, thank you!
完成的
I tried the web too and this is the only thing worked for me thanks a lot!!! RG
完成的
This does not work for phones
完成的
it worked thank u verry much
完成的
添加一条评论
3个答案
已选择的解决方案
Hello,
I have the zte majesty to and last night mine did the same thing when I was texting my sister. I was very upset over this so I did some searches on how to fix the problem and here's what I found.
Go to Settings
Go to Language and Input
Under Keyboard & Input Methods, you should see Android Keyboard (not checked) and Google Voice Typing (checked).
Uncheck Google and check Android Keyboard.
I hope this works for you also.
这个答案有帮助吗?
得分 54
32条评论:
Yes, that worked! I have tried everything on the web but this is the only think that worked.. thanks so much.
完成的
Thank you so much! I've had the same problem for 24 hours and it was driving me insane-r! All fixed now.
完成的
Thanks! I would never have thought of doing that!
完成的
Yes worked for me :) most other forums say uninstall google search from apps but my phone doesn't have any such app :( uninstalled all google app updates cleared data and caches. still got stupid message every time i tried to do anything tried this and now its working properly again :D (samsung pocket neo) Ta Soooooooo Much
完成的
Great! Glad it's working ! It's frustrating when ya can't use your phone.
完成的
显示更多的27条评论
添加一条评论
Dear ginganinja45685 ,
I did find a solution after I tried all possible options, Telstra shop couldn't help on three occasions big Pond telephone assistance couldn't help Telstra telephone assistance couldn't help NBN couldn't help.
Finally NBN operator suggested that I call the phone manufacturer of the Z TE phone, telephone Australia 1300789475
My phone is a "ZTE 83 Dave"phone.
His suggestion was to back up everything on my SD card to my computer remove the SD card and the Sim card and go to
contacts, choose options, click settings, click backup reset, chooseoptions, select factory data reset,choose options, click reset phone and it seems you're done the trick.
These instruction are a little bit scratchy so I suggest you actually contact the factory and get them to run you through it but most important before you contact them
back up all the stuff on your phone to your SD card
then back up all the stuff on your SD card to your computer good luck hope it works for you mine seems to been successful and solve most of the problems so far all seems to be working good.
Regards,
Billco1947
这个答案有帮助吗?
得分 1
1条评论:
My majasty ZTE keeps saying apps not working
完成的
添加一条评论
Hi doesnt work for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 25,591
