跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 GPS not working
Hi,
I have an iPhone 6 and suddenly the gps function stopped working.
If I turn on my TomTom gps it shows "Poor GPS Reception". Sometimes my location is found for a minute and then again it's gone. I've changed the plastic antenna on top of the iPhone without any result.
Is there anything more i can do? I'm pretty sure that it's a hardware malfunction because i did everything i could with the software.
Thx for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
Hello mattis, before touting hardware try to fix by software, have you update your phone to ios9?
完成的
Yes, as I said in previous post, I did everything I could with the software. Restore, update, dfu, reset network settings, ...
完成的
See this thread for the fix!
GPS & Bluetooth work sporadically.
完成的
I discovered a crude solution. Ive noticed that because of wear and tear, my iPhone 6 "sandwich" is a little loose. There is some play on how the screem is attached to the body. Whenever my gps or Bluetooth is weak, i press on the screen to "compress" the phone. Boom. Gps signal restored.
完成的
My GPS had intermittent issues and then finally stopped working. Read a number of different forums that suggested changing the system settings, but nothing worked. Best thing I did was to download a GPS diagnostic app for $3. Turned out there was not satellite reception, which pointed me to an antenna issue. Ordered a new antenna and replaced it, GPS now works perfectly. Could have been that the tiny coax connections came loose and just needed to be pushed back in place, but as long as I had to disassemble the entire phone, it was easier to just replace the part.
完成的
添加一条评论
6个答案
已选择的解决方案
If you restored your network settings and checked all the hardware then you have no more options left. Mine was swapped by Apple under warranty
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
For me - replacement of "WiFi Antenna Signal Flex Cable Ribbon " increased significantly wifi and gps sensitivity.
这个答案有帮助吗?
得分 1
添加一条评论
Nobody....? Still looking for the solution
这个答案有帮助吗?
得分 0
添加一条评论
I have same problem.
Message: Try to go outside but i was outside. After short time: Can not get GPS signal.
Hope somebody find this out
Arne
这个答案有帮助吗?
得分 0
添加一条评论
I am having the same Issue also noticed it shows poor wifi connection even though I know it is a strong signal
这个答案有帮助吗?
得分 0
2条评论:
Wifi and GPS use the same antenna, so probable there is a problem with it.
完成的
replace wifi antenna and cable - sure fix
完成的
添加一条评论
check this part or change antenna two cable up and down
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mattis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 13,982
