跳转到主内容
问题已关闭
My hard drive isn't being recognized
About 4 months ago my MBP wouldn't recognize my hard drive and I took it to Geek Squad and they simply recommended I purchase a new SATA cable so I did (here from ifixit.com). Now, 4 months later, I am running into the same problem. Do you guys think I should get a new cable again or get a new hard drive? Or could it even be a problem with any recently installed software? If so, how can I get into the hard drive to remove that software?.... Any answer is greatly appreciated...thank you!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
do your sata cables have secure connectors or are they just push ons. I have seen sata cables that are just push ons work there way loose to the point of disconnecting the hard drive
完成的
添加一条评论
1个答案
If you can connect to your hard drive again, please do a hard drive test right away with any program.
If any program considers a failing hard drive, start backing up your data right away and planning on buying a new hard drive.
Other than that, the solder on the motherboard on the SATA connector might be loose, have you tried another connector?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 86
