跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
完成的
添加一条评论
1个答案
You might want to check you ingagement lever and see if the cord that goes from the lever to your deck is broke
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bhagwanji Gosai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 121
