跳转到主内容
Repair guides and support for the Leapster L-Max, a hand held learning game system for children ages 4+, developed and released in 2005 by LeapFrog.
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
完成的
添加一条评论
3个答案
已选择的解决方案
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
这个答案有帮助吗?
得分 0
添加一条评论
You plug in the charger to the wall, and then put it into your leapster device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ruth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 6,069
