Unresponsive Digitizer After Attempted Replacement
Trying to replace a smashed digitizer on a iPad 3 4G. I have seated the cable as FAR as I can get it. Literally, I cannot get it any further. (see photo) When powered on, I get no touch at any point of the display, however the LCD works and the startup screen displays.
Is it possible I got a bad digitizer? Orderedthe digitizer from ifixit, so it's not some cheap $20 one from amazon. I can't think of anything else at this point. I don't believe the connector is damaged, shows no sign of that. The cable was not pinched, everything fit together ok.
It is possible that the replacement digi is defective or has a damaged cable. Have you retried the original digitizer?
由 Brian 完成的
The old digitizer is deader than fried chicken, smashed to bits. The ifixit guys said they test each one before sending, so they doubt its that.
由 Matt 完成的
