跳转到主内容
加入维修社区 - 创建账户
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
iSight no work
friendly beloveds, has mine iSight suddenly stopped to work is like did not exist, the system does not find it, what can be? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
10条评论
Sorry, I'm having trouble understanding your english- do you mean to say that the iSight simply does not work? As in the OS cannot detect it? And what language do you speak- someone here may be able to speak it.
完成的
That's a good idea, I could give translating German a go
完成的
Roberto is a common name in both Italian and Spanish speaking countries, luckily I speak both.
完成的
During the Second World War, when Germany, Italy and Japan had an alliance, the Italians nicknamed it Roberto. (Rome, Berlin, Tokyo)
完成的
Anyone here know japanese!?
完成的
显示更多的5条评论
添加一条评论
4个答案
最有帮助的答案
if you go under the Apple Menu, select "About this Mac..." then click on "More Info..." this starts up System Profiler. In the list on the left under Hardware, select "USB" - see if the iSight camera is listed as one of the devices connected to the USB bus. Note that there are internal devices like the iSight connected to the USB, not just the external ports.
if it's not there, it's possible the iSight hardware has died. on the other hand, there's still chance it may be software related. but anyhow I'd start first by checking System Profiler, then go from there...
p.s. Apple has some basic iSight debugging tips here - for example you could try resetting the SMC/PMU. try some of the suggestions there and report back on the results. good luck.
这个答案有帮助吗?
得分 5
添加一条评论
Good idea!!italian or french language
这个答案有帮助吗?
得分 0
1条评论:
Bene! Parlo l'italiano!.
完成的
添加一条评论
For "rab777hp: Ciao,leggendo i vari forum, ho scoperto che probabilmente ho il modulo iSight fuori uso, dal momento che smontare il Macbook non si fa in dieci minuti, ho deciso di acquistare un modulo usato ma funzionante.Appena l'avrò ricevuto smonterò il tutto.Come ho cercato di scrivere, il computer non riconosce iSight, come se non esistesse e vane sono state le varie procedure per rilevare la periferica.Grazie Roby
这个答案有帮助吗?
得分 0
1条评论:
Questo era in Macosxhints.com oggi, non so se sa come fare questo, ma molti dicono che è la soluzione della problema, che è comune ora con molti personi che hanno Snow Leopard.
Mi dispiace se non puó comprendere bene il mio italiano, non sono fluente ancora.
完成的
添加一条评论
No problem,thankyou for your reply. Grazie per il tuo aiuto,il problema l'avevo anche con Tiger,adesso sono passato a Leopard con Snow senza aver risolto il problema.
这个答案有帮助吗?
得分 0
1条评论:
Hmmm, penso che deve ascoltare a i consigli di 'bac', dimmi se non lo capisce.
完成的
添加一条评论
添加你的答案
Roberto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 2,490
