跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
blinking apple logo nonstop
my daughters itouch has been down for sometime now and now it just blinks the apple logo, how can we get out of this?and restore.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hold power button and the home button for ~10 seconds to hard-reset. Specifically, what led up to her iPod dying?
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
fluid damages are pretty bad - and they are getting worse.
when the fluid is gone - it leaves a conductive residue - this residue will act like cancer, it simply "eats" his way through the small parts and circuits.
you can try to fix it with cleaning.
get some isopropyl alcohol and a paintbrusch, disassemble the ipod and clean the odd looking parts (white greenish residue) - clean it carefully - but it must be removed, check the connectors and don't forget the bottom side of the logic board.
let it dry - don't use a hair dryer for that and when it's dry, reassemble it and try to power it on/connect it with the computer
good luck
这个答案有帮助吗?
得分 2
4条评论:
完成的
how do i open the itouch
完成的
oh i have my daughter itouch on the itunes and usb cord mode and nothing else happens
完成的
on the right side of this page is menu - click in step-by-step guides and use the one for the logicboard. and please - stop trying to charge it - it won't help and could finally kill the device!
完成的
添加一条评论
If it has been water damaged and the Apple logo is just blinking, those are signs of possible hard drive or logic board damage.
这个答案有帮助吗?
得分 0
1条评论:
There is no hard drive in the iPod Touch, but a bad logic board is likely.
完成的
添加一条评论
添加你的答案
bunny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 4,314
