跳转到主内容
发布1990年作为苹果 Extended 键盘的继承者。 使用传统的ALPS触点开关或Mitsumi标准机械线性按键 产品型号为M0312和M3501。
2 个问题 查看全部
command shortcuts not working
I wiped down my keyboard with one of those lysol wet wipes and now my command key won't work ... for example: I'm in InDesign and my command C just types a c and doesn't copy. I have the extended keyboard plugged into my MacBook Pro. I wiped down both keyboards. Now I can't figure out how to restore my command shortcuts or if I got the inside of my keyboard wet. But all the keys work as a typewriter, just not the commands. I'm thinking that I somehow locked the command out or something as I rubbed over all the keys, but have no idea. Anybody?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Being able to reroute some keys may help with your trouble shooting or give you a temporary solution. For instance I have rerouted my CAPS lock key to ESC because it is more useful.
This app does the trick:
https://pqrs.org/osx/karabiner/seil.html...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jpgrahamjazz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 239
