跳转到主内容
Won't wake up from sleep mode
Genius staff was unsure of the problem. We tried resetting the SMC, sleep mode adjustments to none, once the screen reboots or comes on, it just wants to sleep. They said it could be the battery(battery is over 90%), hard drive and/or logic board. I am willing to repair if parts are reasonable. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did they even try a different drive and maybe running it external with the hard drive and sata cables unplugged ?
完成的
添加一条评论
2个答案
Is there any chance of a faulty closed-lid sensor? I recently had my MacBook on top of another one, and the magnets in the lower laptop triggered the sensor on the upper laptop, making it think the lid was closed. Of course, nothing you do will get the screen to wake when the laptop thinks the screen is shut.
If you have some sort of magnetic influence, maybe the fix could be as simple as moving your laptop to a new location. If not, maybe your sensor has gone bad, and is constantly thinking the lid is closed even though it’s not.
You could try using an external monitor, keyboard, mouse, and trying it all while plugged in. This will bypass the sleep sensor on the lid.
这个答案有帮助吗?
得分 0
添加一条评论
Try terminals solution:
MacBook falls asleep
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kerry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 156
