跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
After Repair: Home button working, Touch ID not
I just finished swapping my screen after two cracked ones and a malfunctioning one. After these three fixes, everything was working perfectly fine (except for the screen on the last two changes; bought from the wrong person I guess). Now, after putting in the newest screen (and having to readjust the cables as one wasn't in all the way, making this newest screen malfunction…) Touch ID is no longer working. When trying to activate it, it sends me to a "Failed" screen immediately after trying. Does anyone know what this problem would be? I've tried readjusting both Home button connections and nothing seems to work. If I did damage it, can you give me a link to the part I need to repair it? Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You have to use the OLD home button. I f your new screen came with camera and home button already installed, that is usually the case.
这个答案有帮助吗?
得分 0
2条评论:
It is. That's the problem.
完成的
could you be more precise? what IT IS means - you tried it or it comes with home button?
完成的
添加一条评论
Try to reset the touch ID. Your old touch ID data has been disable after screen replacement.
这个答案有帮助吗?
得分 0
2条评论:
How'd you go about doing this? Is it something in the OS or the hardware?
完成的
Just reset everything. Nothing. Any other ideas?
完成的
添加一条评论
Your Touch ID is linked to the device you can't replace with new button without loosing the Touch ID function.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 375
