跳转到主内容
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
How to solder new LCD FCP?
Hello all...I'm working on rehabbing an ipad 3, one thing that needs to be done is to replace the fcp for the LCD connector. I've removed the old one, that was no problem using Chip Quik. But now I'm trying to figure out th best way to solder the fcp on.
Specific questions are: 1.) what is the best way to keep the fcp in place before it is tacked to the logic board? 2) Which is better to use - soldering iron or hot air? 3) What type of solder is used? 4.) What about flux? 5.) Should the traces be tinned?
I've looked through many online videos, but very few to choose from so any help will be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hello Chris,
its not a hard work to do. you can simply use Lead-Free Solder Paste tube for soldering. not required additional flux to be added. keep hot air 430C. task is you should have to solder FPC connector withing 6 seconds otherwise FPC connector begin to melt. simply you can use tweezer to hold FPC connector or can use SMD glue to hangs it to logic board. contral the hot air otherwise surrounding components flies away.
Cheers!
这个答案有帮助吗?
得分 1
2条评论:
Buddhika, which lead-free solder paste do you use? Not very familiar with using solder paste, what's your process for using it on a repair such as this one? Does the paste have to be applied exactly on each trace or can the paste bleed from trace to trace?
完成的
This one is better
http://www.ko-ki.co.jp/en/products/solde...
BGA reworking skill required for the FPC replacement
youtube will help you to learn
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 868
