跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
My iPhone 6plus is over heating and screen will not work?
I got my iPhone 6plus wet, not a lot but still wet. I dried it off and it was working fine, then it started to to crazy random stuff with screen after i plunged it in to charge. The screen eventually quit working all together with in minutes and it gets crazy hot on the back of the phone where all the connectors are for the screen. I have completely removed the logic board and soaked it in 93% rubbing alcohol for 3 days let dry for three days resembled and it still doesn't turn on but gets really hot still when I plug it in. Whats my next step? Trash it, or is there still hope?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Bean, more than likely the heat is being generated by an electrical short. The minerals in water will cause corrosion that will build up and eventually start to bridge components and connectors that should be isolated. To find out if this is the case, you will have to examine the logic board under a microscope or if you don't have one, then use the strongest magnifying glass that you can find. Their is some protective tape that surrounds the LCD, Digitizer connectors. That tape can be removed from the logic board, do it carefully so that you can reuse it later when reassembling. Once tape is removed you can view the solder joints for the different connectors, Look for corrosion around the LCD and Digitizer connectors as well as all other parts that are on logic board that are not covered with the metal heat shields(both on the logic board and on the end of the flex cable). If you find some, then use a fiberglass scratch pen or soft toothbrush to remove corrosion. Rinse with alcohol.
Water and electricity are a bad combination. If corrosion is not the problem, then you may have board level issues such as a blown filter, ect.
这个答案有帮助吗?
得分 1
1条评论:
Also, the battery will have to probably be replaced. The now shorted out battery is another candidate for the source of heat that is occurring when the phone is plugged in.,
完成的
添加一条评论
添加你的答案
Bean 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 231
