跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Swollen battery after screen replacement
Had my screen replaced some months ago due to a crack in the glass. Battery is now swollen and phone will no longer charge or power on. I'm not sure if the battery deterioration started before or only after getting the screen replaced.
Wondering if it is likely the battery was damaged in the process of replacing the screen or if it's an unfortunate defect in the battery that was likely there from time of purchase?
Any input appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
No, that is highly unlikely. The only way that would happen is if you somehow pierced the battery allowing leakage and causing it to expand. It may be from high temperatures from excessive use while charging or something like that.
这个答案有帮助吗?
得分 4
1条评论:
Thanks. I don't think I really used it while charging and definitely didn't overcharge it. Never used any accessories other than what came in the box with it either so figured it was a fault with the battery from purchase. Now to convince the retailer of that...
完成的
添加一条评论
Doesnot necessarily have to be pierced for the battery to be swollen. infact if your phone is More than 18 months old then most likey the battery gave up. Just change the battery and you will be fine.
这个答案有帮助吗?
得分 1
1条评论:
Phone was only about 6months old when this started so I'm hoping to get it repaired/replaced by the retailer if it's a case that it was faulty when I bought it. Hard to prove I guess.
完成的
添加一条评论
Its much more likely the charging system was damaged at the same time the drop occurred that cracked your screen.
这个答案有帮助吗?
得分 0
2条评论:
Is there any way to check for that?
完成的
I actually had the exact same problem actually that's what probably cracked your screen because I noticed a blue discoloration dot on every white page I went to on my iPhone so what happened was the battery was pushing up on the display so I went into Apple they told me about the battery and swap my iPhone 6S out with a brand new iPhone 6S so yes you're theory is probably right it happened at the purchase and the guy who replaced the screen just failed to tell you about the battery
完成的
添加一条评论
I had the same problem, changed the scream on my phone. Two weeks later battery swole up. I took my phone to Apple Store, they replaced my phone under warranty.
这个答案有帮助吗?
得分 0
添加一条评论
Can a swollen Battery cause the touch on the phone to become non-Functional.
I replaced my iPhone 6+ screen with a new one. However, the issue remains. I hard reset the phone it will work for a couple seconds then everything freezes up. Is that the battery or the Logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gof 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 12,433
