跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
20 个问题 查看全部
Does anyone know how to tighten the hinge on this?
My xps 13 (2015) is making cracking noises along the hinge, and i think thats because the hinges are loose. Anyone know how to tighten it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
7条评论
Hi, I am having this issue as well. Could you tell me how you removed the cover?
完成的
I have the XPS 15, which is built very similarly. I'm also having this issue. You need a small set of torx screwdrivers to open up the back. I found a good set on amazon a while back for around $5 I think
完成的
The trick is to find the screw under the service tag flap
完成的
Anyone tried isasukexd's answer and still have this wobble?
完成的
The dell XPS is famous for the loose hinge, then. My XPS L321X (2012) also have the issue.
Yes, the brackets under the backplate (screwed onto the chassis) can be loose, but it's not that loose. The screw that is the loosest is the one on the display.
How to tighten that?
First, open up the cover (like you are using it)
Use your fingers, pinch the top and bottom sides of the plastic part (on the screen). Then pull toward you. (away from the screen). A plastic tab on top should reveal.
Close the screen (like you are done using it). Use your hands, gently lift up the plastic part. Antennas should be connected to it. The screws are Philips white (can be black) ones behind the display cable and the antenna.
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Ive fixed it! If anyone else with an XPS 13 is having this issue, take the back off and tighten any loose screws on the top left and right, where the hinge is located.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
isasukexd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 12,847
