跳转到主内容
The Nyx Noba version runs on Android 4.1.2 Jelly Bean , has a 1 GHz processor speed 512 MB ​​RAM, 4 GB internal memory for all our files and apps, others have a slot for microSD up to 32 GB, and includes a 4GB microSD card.
1 个问题 查看全部
The flash of a Nyx Noba cellphone is always turned on.
Hello.
I have a cellphone Nyx model "noba" which his flash doesn't turn off. I mean the flash always is turned on, even when the cellphone is turned off. The only way to turn off the flash is removing the battery from the cellphone. Is this a problem related to hardware or software? And how it can be fixed?. I hope someone can help me. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Disassemble the phone and look for a possible corrosion and shorts. Most of the flash "always turn on" problem occurs when parts shorts with the other component.
Or it you may want to look at your apps (i.e. flashlight,dimmer,bulbon,etc.) it might be in the "turn on" mode operation stucked into it.
这个答案有帮助吗?
得分 2
1条评论:
Thanks. I'll try it.
完成的
添加一条评论
添加你的答案
Gerardo Hernandez Molina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 251
