跳转到主内容
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 个问题 查看全部
Ink on notification LED, best way to remove it?
Hi all, long story short, there is now Sharpie ink on the notification LED under the speaker grill on the front of the phone.
I know I can remove it with rubbing alcohol, but trying to leach it off by letting alcohol set on the grill & then soaking it up with a QTIP failed to remove it, it just diluted it and let it spread out over the LED even more, so now it's all but invisible.
Where is the LED located? Is it on the back side of the logic board, or all the way in the front display assembly? Can I just leave the ribbon cables in place & flip the logic board back to clean it off, or will I have to go all the way to removing the glass?
Thanks in advance for any help.
Regards,
Jesse C.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I would try Nail Polish Remover and Q-tips. But soak the Q-tip with the remover, do not apply directly on the machine. Once you do that immediately follow up with rubbing alcohol (90%) to clean up residue from the remover.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the tip. I already tried soaking the Q-tip & then trying to rub it off, but it didn't even dilute it. So, I applied it directly & it did dilute the ink, but then I have no way to remove it completely without disassembling the phone.
The main thing I need at this point is how much do I need to disassemble the phone? I assume the LED is just on the back of the logic board, but I can't be sure that it isn't the the front assembly with the LCD panel.
完成的
添加一条评论
添加你的答案
geniusdog254 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,329
