跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Help itunes error 9
I can not Restore my iphone 6 due to an error 9. What does error 9 means and what i have to do to make it. NEED SOME HELP PLEASE.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I believe that error 9 relates to some kind of fault with the internal storage.
No easy fix available.
Provided you haven't done anything to invalidate your warranty with Apple - get it back top them quick. They should see you right, and will likely give you a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
Error (9) can me a multitude of different things. My error (9) was because of corrosion on the lcd flex cables that wouldn't allow the phone to boot, therefore I couldn't restore it. But when I unplugged the LCD completely I could get it to fully restore. Now my iPhone works, I just had to use isopropyl alcohol to clean all the corrosion off the PCD flex cable connectors. Sorry if I am bad at explaining im 16.
这个答案有帮助吗?
得分 0
1条评论:
Something similar myself.. I disconnected the rear facing camera whilst restoring and it worked absolutely fine.
完成的
添加一条评论
添加你的答案
Papo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 951
