跳转到主内容
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
My triggers and (a) button dont work
hey i was doing some diy mods to my xbox one controller (i changed the d-pad triggers bummers and joy sicks to white) and now my trigger either are unresponsive or are shooting and aiming non stop. also my (a) button only works in game when i go to the xbox menu or homescreen i have to click the button 3 times to get it to work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
bump? i still have this problem
完成的
添加一条评论
3个答案
hey Im having the EXACT same problem (even the xbox menu/in game 'A' button issue), bumping for some help.
这个答案有帮助吗?
得分 0
1条评论:
have you found anything out?
完成的
添加一条评论
I have the same problem. What happened was I accidentally scratched the magnetic sensor for the triggers and now I have to order a whole new mother board and I don't know about you a button....
这个答案有帮助吗?
得分 0
2条评论:
can i ask were you bought the new board from ? and it is only the one board or are you buying both
完成的
Well I bought it on this web sight but you can probably find it cheaper if you do some research but I only needed the thumb stick mother board or the bottom to fix the trigger but if your a button isn't working too your best bet is to buy a new controller because to fix that you need the other mother board...
完成的
添加一条评论
I have the same problem, i bought the controller new (the warranity expires 2 days after) the left and right triggers are not tight but they keep aiming and firing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
killerbunnies KB 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 1,186
