跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Phone works perfectly for 2 mins then Blue screen and restarts?
So after an issue with the phone not charging, I replaced the charging port (oem apple iPhone 5s from donor phone) , and the battery as the battery had decreased its ability to hold a charge.
Rebooted phone and it is working, however after a couple of minutes of use it crashes with a blue screen for a second before restarting.
I have researched this and the BSOD appears to be a different fault caused by the overtightening of screws damaging the 7 bus lines on the PCB. I am sure this is not my fault.
So I have tried different batteries, checked and double checked the repairs I have done (charging port).
I have done the basics of restore and reset with no change in prognosis.
I am sure its something simple any ideas?
The only thing I haven't done is changed the screen, there is as always a possibility that a cable has been damaged here during works, but for now its working as normal??
Please Help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have same symptoms...but no IMEI, modem firmware, ICCC...and every time network searching but no signal...wifi worked OK...location/compass not working...on wall charger not charge but charge on PC. Power Off iDevice...and when Power ON he is discharged...
完成的
添加一条评论
2个答案
已选择的解决方案
that could be your front cam flex or the usb ic u2 chip going bad. since you already had charging issues that could very well be the issue. when that chip fails you start losing the ability to charge and sync the device. it will also BSOD. if you damaged the traces during the repair it wouldnt even boot to home screen. it would keep boot looping and bsod.
这个答案有帮助吗?
得分 2
添加一条评论
i read about a screw of the emi shield above all fpc connectors.
maybe you took the wrong screw(position down right) and damaged some cables on the pcb
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darren McElhinney 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 189
