跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
问题已关闭
LCD fades away after I install new screen in new housing
I recently installed a new screen on an iPhone 6 along with a housing swap. immediately after putting the new screen down the LCD slowly fades away.
Any way to solve this issue please respond :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The plug for the lcd is not connected fully or the ribbon cable is pinched inside the casing.
You will have to open it again to check the connection and cable.
这个答案有帮助吗?
得分 0
2条评论:
what do you mean pinched
完成的
As in the cable is caught somewhere, usually between the casing and screen. I am assuming when you lay the phone down it pulled the cable slightly and the screen shut off.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 57
