跳转到主内容
The Samsung WB150F is a 14 megapixel camera with 18x optical zoom and Wi-Fi connectivity.
14 个问题 查看全部
问题已关闭
How do I change the clock battery?
I hardly use my wb150f digital camera but when I tried turning it on, nothing happened. I pressed the button and the light turned red and nothing happened. I googled and found out it could be the clock memory battery. I took apart the casing and I'm a little hesitant in just pulling out the battery. I read that some batteries are soldered in. Does any one have any suggestion.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Arnold,
I would like to encourage you to continue pulling out the battery - for me it rather looks to be fixed with some kind of metallic clamps, not soldered.
However, at the moment I cann´t help how to remove the battery.
Instead, I am trying to solve the over exposure problem of my camera - caused by moisture. Had the lense module open in my hands but did not consentrate to the battery at that phase.
Good luck,
Asko
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 174
