跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Knocking sound when tilted - around top of keyboard or screen area
There is a distinct knocking sound when tilting the Macbook. It feels like something is sliding and knocking the metal casing, but it's extremely had to identify exactly where. It sounds and feels like something heavy, possibly a battery, but the batteries are towards the front (and stuck down!) The knocking sound is coming from the bottom of screen area, more towards the right but across the length of the hinge.
This has baffled me and there appear to be more people with this issue - is it the fan moving on it's axial?
Is there something loose in the screen itself? - it does sound like something heavy, flat and moving side to side (it's absolutely not a loose screw or something 'rattling' around).
Is there a solid metal bar/fixing in the hinge area it could be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
You'll need to bring it in for warranty repair that's not good for a new system!
完成的
添加一条评论
1个答案
最有帮助的答案
If the sound repeats its the fan blade hitting the fan housing as the bearing is bad. As long as you haven't banged your case this should be able to get this fixed under warranty given your systems age.
Bring your system into an Apple Store or Apple authorized service center to be looked at.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jaybe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,036
