跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
What can I do if I forget my password?
Someone stole my ipod and changed the password when i found it i didn't know the password so i need help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
You can do it, but it requires the iPod touch to be reset, hopefully you have synced it recently with iTunes before it was stolen?
Ok so connect your iPod to iTunes
Hold power button and Home button (circle button) at the same time, maybe around 8 to 10 seconds.
It should now reboot (screen will go off), release JUST the power button, keep home button held down.
iTunes will say it has found an iPod in recovery mode.
Now just restore your iPod with your iTunes.
It will wipe everything first, then put it back on.
这个答案有帮助吗?
得分 2
2条评论:
Dude. thank ou so much.
完成的
OMG it will delete all my photos!!!
完成的
添加一条评论
it better to get restored.
这个答案有帮助吗?
得分 1
添加一条评论
Can’t access your iPod? To reset a lost iPod password, follow these instructions.
1. Plug your iPod into your computer.
2. Make sure you have the latest version of iTunes.
3. If necessary, back up all your music. Though you may think that this is impossible with a locked iPod, the screen lock only protects the iPod interface itself; it doesn’t protect/encrypt any of the data inside, meaning you can still access it from your computer.
4. Restore your iPod. This will clear its contents and restore all factory settings.
5. Re-sync your iPod and apply a new password.
More from: http://www.wikihow.com/Reset-a-Lost-iPod...
这个答案有帮助吗?
得分 0
添加一条评论
it doesn't work!!
这个答案有帮助吗?
得分 0
添加一条评论
thank you man you are the best
这个答案有帮助吗?
得分 0
添加一条评论
Well, i just have the same experience with you. forgetting the passcode of a iDevice, but my iDevice is an iPad. But i think maybe the way to solve the problem is similiar, so i recommend you to refer to https://www.isunshare.com/iphone-ipad/re....
Hope to be helpful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jaylin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 5,569
