跳转到主内容
The Sony Xperia E3 is a slim, lightweight 4G smartphone, released in September 2014.
18 个问题 查看全部
Power button restarts the entire phone.
For the past 24 hours, when I hit the power button my phone restarts - I've no idea what triggered it, and can barely use my phone now as every time I need to use it the phone has to restart (once the screen turns off, all I can do is hit the power button - which just restarts).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
i still can't fix it but for alternative solution, you can install apps called "Power button to Volume button". It was help me. Not bad.
完成的
添加一条评论
4个答案
已选择的解决方案
I have same problem. I was brought it to sony service center, after 5 days checking, customer services said that my phone's power button and LCD need to replaced. I was suprised. Why the LCD must be replaced too? And then I was waiting for about 5 weeks of repairation, my phone's button is back to normal but not so long, just for 3 weeks.
I've try to using apps like proximity action and smart screen on/off -> not working
Factory reset -> not working
Try this solution offer (Sleep of Death -Power button Display Issues) -> still not working
这个答案有帮助吗?
得分 4
1条评论:
Dear buddy , I have the same problem... Your post was of 2015.. hope you found the solution... How u fixed it... I did
1. Factory reset - dint work
2. Xperia Campanion repair - dint work
3. Sent to repair shop for updation of software- dint work
完成的
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
Hamara mobil chek fail batats h
这个答案有帮助吗?
得分 1
添加一条评论
please open the back cover and find off button in hole press this button...your phone will
automaticly restart..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iamsimoncolton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 19
总计 5,994
