跳转到主内容
Released June 2014, identified by model 635.
54 个问题 查看全部
My Nokia Lumia 635 is acting weird
I was updating Dragon Mania Legends and the download progression says "pending" and it's been like that for 5 days, also power button refuses to shut off the phone but works by holding the button down to turn off the phone, battery indicator froze, and every time when i connected it to my computer, it refuses to let the computer recognize the phone. and the phone sometimes froze. Is there a way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Have you removed the battery? I am assuming you probably have, but removing the battery and the putting it back in normally repairs those kind of issues.
完成的
@gatewaynomad I tried that, but my phone still kept on acting weird.
完成的
添加一条评论
1个答案
最有帮助的答案
That happened on various (different) phones of mine through my life.
Consider doing a factory-reset state formatting, this could solve not only this issue, but make your phone faster (it "refreshes" the phone), but take precaution with your data (remove the SD card!) before that and copy all your contacts to your email provider account (meaning, do not have only one copy of the contact, as the formatting will erase your personal data on the phone), write them on an office excel sheet or paper if necessary. Also, this would erase all your downloaded and installed apps that didn't come on-default with your phone.
Hope it serves you
Narmith
这个答案有帮助吗?
得分 2
1条评论:
Thank you @Narmith, that helps just fine.
完成的
添加一条评论
添加你的答案
Brandon White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 348
