跳转到主内容
Gateway laptop identified by model #MT3707
Why does my gateway keep shutting down
my gateway laptop boots up then blue screens and then shuts down and repeats the cycle. i cant get into bios or anything else, what do i do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Well it sounds like some kind of hardware has gone bad, remove the HDD and retry, then remove 1 RAM module and retry, if still the same the remove the other RAM module and replace the one you just removed, and keep going with parts that you can take off the motherboard, might try to remove the CMOS battery and try to boot and see if there is a change, let us know if you try any of these options and update us if anything helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mizbooboo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 272
