跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How to fix my frozen iPhone
My Iphone keeps freezing, I've let it run flat and then recharge it and then it worked for a couple of hours and now its frozen again. I cant restart it because my lock button doesn't work and my computer needs me to respond on my phone for it to be restarted on Itunes help me what can i do?
Also the screen doesn't respond to me tapping on it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hello Tara,
The only way to get out of this is to open it and disconnect the battery (as a temporary workaround). Since the power button is not working, you need to plug it in a power adapter for it to switch on. If it's still freezing then you probably have a defective Logic Board.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
If nothing else is working you can force it into recovery mode. As your lock/power button isn't working you can use a software called Tenorshare ReiBoot that will do it. It also allows you to exit recovery mode and get your phone on again.
As it is freezing all the time it sounds like you might need to do a restore as something may be corrupt. Just back everything up and then restore it back on your phone.
If it is still freezing after that you might have to just try restoring it and setting it up as new.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tara Lieschke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 216
