跳转到主内容
由华硕制造的笔记本电脑。
2523 个问题 查看全部
My touchpad wont work (device could not migrated)? HELP
OK guys i have had no cursor unless I'm using a mouse, i have tried everything but in device manager it says in the event log error device could not migrated? How do i migrate it or fix it, my laptop is Asus X550-ZA. It also gives me error code 24 (This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)) any body else have this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
just uninstall the touch driver or try restoring the computer if not than install updates in system for more https://goo.gl/vJjEec and i am sure this will help .
完成的
添加一条评论
2个答案
I am also having this problem on my Acer Aspire V7, device manager says it is working fine but the cursor doesn't even appear unless I have an external mouse plugged in. Changing drivers did nothing
这个答案有帮助吗?
得分 0
1条评论:
yes bingo same here
完成的
添加一条评论
This is how I fixed the problem.
brought up task manager
went to "services" tab (last tab)
Went down to "Launch Manager Service" (LMSvc)
Right clicked, selected restart.
Mouse returned
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pois0nz Tech Videoz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 4,836
