跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone no service, cleam imei, correct date, good antenna, so how?
Hi I am a phone technician and I recently purchased a phone from a friend, iPhone 4s - unlocked.
I was able to use the phone on multiple network without a problem.
I changed the LCD, and attempted to use the phone a few days later but I was greeted with no service..
- Date and time is correct
- Antennas are fine
- Sim cards are fine
- all connections etc are fine.
- Clean IMEI checkmend clear
- Tried airplane mode toggle
- Tried battery
It searches for signal and then says no service, if I go to contacts my number is displayed at the top, I have had it on WIFI and iTunes, I have also updated to latest software, I also did a full reset and set up via iTunes and when it connected it said congratulations your phone is unlocked. No matter which sim card I try I get the same results.
I have tried everything I can think of, does anyone have any other suggestions please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Sometimes (iPhone 5C has that problem more often) the time and the date is good but the year is 1970 and you can't adjust it right. Its motherboard problem, no solution.
这个答案有帮助吗?
得分 0
1条评论:
Date year is correct also
完成的
添加一条评论
To connect the time and date must be set correctly but otherwise it will be a logic board issue. there are several small components that if damaged will prevent connection. check all parts around the battery connector for continuity the smaller components are related to network connections.
这个答案有帮助吗?
得分 0
1条评论:
But it seems to search for network though, I will have to take it to the specialist to take a look at the motherboard, thanks
完成的
添加一条评论
添加你的答案
Kbobble 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 307
