跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30、60 或 80 GB 硬盘 / 黑色或白色塑料面板
click wheel button feels stuck
the button is not flush with the actual wheel it feels stuck, but yet it works if you press hard...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
2个答案
最有帮助的答案
Definitely use the click wheel button replacement guide. When you get the click wheel off of the board it sits on, you'll see some tiny circular rubber bumpers, one on each button. You'll find that the rubber bumper that holds the center button "up" has slid off to the side. Just pull it off, use some good glue to stick it back right to the center where its supposed to go. Let the glue dry, then just reassemble by following the guide in reverse. Should be good to go.
这个答案有帮助吗?
得分 6
2条评论:
Had the same problem with a stuck button and this suggestion worked
So thanks bcrismon, my iPod is up and running again!
由完成的
Brilliant! Very fiddly but very doable.
Repositioned the little black pad on the centre button and my iPod is good as new. Saved me £250 buying a new one. Why Apple abandoned the classic wheel system is beyond me.
Thanks for the help
由完成的
添加一条评论
use the click wheel button guide
to disassemble the ipod and clean it carefully - then reassemble it again.
if you have to use fluids - use only isopropyl alcohol with more than 90%
remove the dirt/sticky stuff from the click wheel area and the ipod should work again after you resassembled it - but if you clean it with alcohol - let it dry before you reassemble it
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Bill 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 12,334
