跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
How to bond frame and glass together
Hi everyone,
I just had a question on what type of glue/bonding you use for putting the frame and glass back together. I know you use LOCA for LCD&Glass only repairs but what about the frame. Also I have done a few Samsung Galaxy glass only repairs and the glass keeps popping on the top edge. I've used different types of double sided tape but nothing seems to work.
Any input or help would greatly appreciate it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Gorilla glue epoxy might be the answer here. I'm currently looking for the exact same solution and although super glue gel seems a possibility it doesn't mention glass anywhere in its uses. Gorilla glue epoxy specifically says it will stick glass. Around £5 for 25ml so probably well worth a pop
这个答案有帮助吗?
得分 0
3条评论:
Yes, but what about if they cracked the screen again and you need to replace the glass only. The epoxy will not come off. I worked in the healthcare industry and I used to use a industrial strength silicone adhesive that bonds strong. I've been doing some test with that to see if it works. And is bonds to glass,metal,plastic and much more the only problem is that it's from Japan.
完成的
Fair point but since a replacement frame costs less than £1, if the device comes back in for repair again a new frame could be fitted easily enough. This is probably more cost effective than the price difference in the silicon glue vs apoxy. But I suppose it's down to personal choice and what you prefer working with. I know that plenty of repair places just use the 3M strips and don't care. Simply because they generally end up coming to us when the screen drops off 2 weeks later!
完成的
Thomas, you make a good point on the frame replacement. I'll give it a shoot thanks for your input.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 196
