跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Home button functionality not working
Started as home button not clicking unless you pressed hard enough to distort the LCD but the fingerprint worked fine. I harvested three other buttons with success of the home button clicking. Now the touch ID doesn't work on any of the harvested buttons. It's like 1 step forward 1 step back. What are you thoughts? I am curious to hear what other techs have to say about this similar but different issue. I put the original button in which doesnt click and turned assistive touch on, even with assistive touch on the home button still doesnt work using that function. This is a strange bird :O
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Does the button click when not in the screen? If so, try loosening the screws where the home button plate goes in as it gives space sometimes, this is usually with third party screens.
这个答案有帮助吗?
得分 1
添加一条评论
The iPhone 5S home button is linked to the original motherboard it came with. If you replace the home button, you will no longer have Touch ID functionality. There is no getting around that, unless you pay Apple to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
I have seen some posts saying its part of the board and also part of the charge pot area. The button clicks but it's not being recognized. I've talked to other tech that have successfully harvested and replaced buttons. Keep the info coming hopefully we can nail it down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 152
