iMac, crazy fans and no screen!
Hi all,
First post here looking for some help.
I've been given iMac by a family member due to it not working. It looks like someone has opened it before, as the cable to screen have been damaged :-(
However the iMac turns on but the screen is black. It chimes,as usual hard drive and everything boots up, but no picture. After about 10 seconds the fans go into mega overdrive.
I've plugged it into an external monitor and the screen appears fine on there. But it doesn't boot to anything just hangs.
I've tried resetting the PRAM I think it is, no change.
I've even tried holding down D upon startup, but the fans are going so mad I don't want to damage it further. Any ideas what this could be so I could order a part to fix it. I was hoping this could diagnose what the fault would be
Any advice would be greatly appreciated.
Thanks,
James.
1条评论
Asle,
Thanks for the quick reply. I've opened up the iMac got the LCD off fully now. When I opened up the iMac the LCD was just literally put back in with screws, and all the cables disconnected, so someone had obviously thought, i'll just throw it back on.
Currently I have it connected to external monitor, with the LCD totally disconnected. Looking at that guide, and the back of the LCD is appears that the person has ripped off the LCD thermal sensor cable. Everything else on the Mac, appears to be plugged in perfectly. Regarding the 4 LED lights, 1,2,3 all light up. The number 4 doesn't light up at all.
Obviously this is all done, with the SCD screen unattached.
由 Theoriginal1981 完成的
