跳转到主内容
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
25 个问题 查看全部
How do I get passed security pattern screen ( forgot pattern)
Security issue with pattern screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
3个答案
最有帮助的答案
Try to do a factory reset and let me know if it helps.
Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
这个答案有帮助吗?
得分 4
1条评论:
will i lose any of my stuff
完成的
添加一条评论
There is a reset button on the back. Press that. WARNING!!!!! It will shut down everything so there will be nothing left on it!!!
这个答案有帮助吗?
得分 1
添加一条评论
I need help i can't get in mine I don't have any locks it would not even let me swipe up to get in.( sorry if I missed spell a word I'm only 11)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bailey Hawkins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 11
总计 1,662
