跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Differences between ipad 2 EMC 2415 and ipad 2 EMC 2560
I am replacing the digitizer on my ipad 2. On the tutorials it states there are 4 different models. cdma, gsm, emc2415 and emc, 2560. are all of the digitizers the same for all of these models or does it have to be specific.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
As far as I know, all iPad 2 digitizers are compatible with one another. I've never had to buy one by model number.
这个答案有帮助吗?
得分 4
2条评论:
Indeed, when it comes to the front panel of the iPad 2, it's one model fits all.
完成的
Not true, make sure what chipset you have, either you have the A5 chip or the A5X chip. They are completely different on the inside and different flex cable for all the components including the digitizer and lcd screen, the logic board is different also.
完成的
添加一条评论
Добрый день! Подскажите как я могу определить какая у меня модель именно по EMC. Так как у меня на задней крышке не указан EMC. У меня Ipad2 WiFi на 16 Гб. Можно ответить на email: Maks_rehayhyider@mail.ru Заранее спасибо.
这个答案有帮助吗?
得分 1
添加一条评论
Not true! They have different type? Depending on what chip it has. If you have the A5 chip or the A5X chip make sure you know which one you have. A5 and A5X are completely different internal and are not compatible
这个答案有帮助吗?
得分 1
添加一条评论
They look exactly the same on the outside but totally different on the inside. That’s what emc are for buy the correct parts. Also if you have the A5 chip or the A5X chip those are completely different internal also.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,397
