跳转到主内容
加入维修社区 - 创建账户
wifi is greyed not working after restore
ipad air 2 wifi not working after replacing lcd and restoring
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
Hello,
This wifi grey for iPad 95% due to malfunction of wifi port/board "''something that connect the wifi cable network"it is small board in the main PCB. change this port/board and your problem solve like forever.http://postimg.org/image/tkrzc35nr/
这个答案有帮助吗?
得分 2
2条评论:
where can i find this port/board?
完成的
@nimesh you need to get it from your local repair shop that have a spare for this 1. not sure if there any china supplier sold this.
完成的
添加一条评论
最有帮助的答案
Did you make sure you didn't cut the wifi cable? Saying that, cutting the cable usually doesn't cause it to be greyed out.
Did you restore because it was greyed out? That wouldn't solve a hardware issue.
这个答案有帮助吗?
得分 2
添加一条评论
You most likely cut the wifi cable upon removing the digitizer. This can be very difficult not to do. Pull the digitizer back up and inspect the cable that is screwed to the frame to the right of the home button. See attached picture for location.
这个答案有帮助吗?
得分 2
1条评论:
You can't repair greyed out wifi with a new antenna, it's like replacing the tires when your car's engine won't start.
完成的
添加一条评论
Try to disconnect the battery for one hour and then connect it again. Restore and everything should be cool.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
listener 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 5,505
