跳转到主内容
主板和 CPU 维修指南。
166 个问题 查看全部
Power adapter light goes out
When the power cable is plugged into laptop, the light or power is off.
Cable is good, and power is present at connector on motherboard. Connected a power supply to motherboard and slowly increased voltage. At around 1 volt the supply tripped off. Suspect a bad power distribution regulator. I need help finding and replacing this part.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If your computer refuses to boot or tends to turn off without warning, see the Faulty Power Supply to Motherboard problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fshbustr 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 10
总计 161
