跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Home button not working.
I'm having trouble with my home button... Anyone know what the resistance across the button's two leads should be?
I measured 6.3k across with the button pushed down. And I'm suspecting that is the issue. Should the leads go to 0? I may have a problem on the doc side too. The reading across those leads is 47ohms. I thought this was a little low.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I noticed you never got an answer to this. Are you still having this problem?
完成的
添加一条评论
5个答案
已选择的解决方案
I was able to isolate the weak short to the mother board. Instead of replacing the phone I was able to jail-break it so I can now use slide gestures to simulate a home button press. Phone is working fine, but I'm wondering how long it will be until that short reveals it's negative effect on other circuitry. With any luck it's isolated to the home button.
这个答案有帮助吗?
得分 2
添加一条评论
I had the same issue. I opened up my iphone with help of this website(Thanks to them) Then i saw under the home button is and one of the matel bit was broken so it was not touching the circuit borad.
Have a look at it may be that is the issue.
这个答案有帮助吗?
得分 1
添加一条评论
i had a similar problem, but the home button seems good, so i changed the speaker module. it works fine now.
这个答案有帮助吗?
得分 1
添加一条评论
ive had that problem and what worked for me a couple time is try lifting the little tabs behind the button that makes contact , carefully lift them and if that doesnt work you can always replace the button or use the jailbroken app called ( Activator ).
这个答案有帮助吗?
得分 1
添加一条评论
In a similar way to Jay and Albert, I simply cleaned off the contacts between the display and dock connector. Then I bent the small metal tabs on the display positioned opposite the two metal pads on the dock connector (this is what connects the home button). After that, the button worked fine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 9,510
