跳转到主内容
Repair information for printers made by Canon.
427 个问题 查看全部
Bad Color prints - Refilling, Cleaning helpless.
Hi,
I had Canon Pixma MG3570 Printer which is multi-functional wireless printer.
For the first time the cartridge got empty. So i refilled the Black & Color cartridges upon emptying.
Since then, I have problem in printing color pages but only black photo copying works fine(not gray-scale prints which have random faded/deviated colors or stripes upon printing).
The sample test print (pattern & alignment check) are included as attachment.
I have emptied & completely cleaned color cartridge with water & dried & refilled. Even though same problem continues.
Please Help me in rectifying it.
And also i would like to know availability of:
1> Any reset software are for this printer (like MPTool or any other).
2> Dis-assembly & assembly manual or video.
3> Any other immediate maintenance required (like waste ink pad cleaning or ...)
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It looks like the print heads are partially jammed. Cleaning them should resolve your problem.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you JohnnKlein14 for the reply.
May i know the cleaning procedure for this cartridge (CL-741).
Do i need to cut & open this cartridge to clean( is it sufficient to clean with water or need any solution particularly).
Which is the best way to clean it.?
Precautions, if any ... to keep in mind before doing this.
这个答案有帮助吗?
得分 0
1条评论:
A1Star did you ever resolve the problem with your 5320?
完成的
添加一条评论
添加你的答案
a1star 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 7
总计 1,170
