No service on iPhone 5s
Today, my wife's iPhone 5s suddenly lost cellular signal and says no service. I tried the standard routine - rebooted, airplane mode on and off, reinserted SIM, switched SIM from different phone, reseted network settings - still the same issue. The phone shows ICCID, but can't find any carrier. Interestingly it is able to connect to the network partially. Inside of the house, where my iPhone 6 gets full edge signal, my wife gets no service, however outside, where I get only two dots of LTE, she also gets two dots. So maybe her iPhone is able to connect to LTE but unable to connect to edge? Have anyone else ever encountered such issue? Are there any known fixes. Do you think it is worth trying to replace the cellular antenna flex?
Thanks.
5条评论
Was the phone subject to a prior hard drop or liquid damage? Anther just happened that may have triggered this? And finally, is it still under warranty?
由 Rany 完成的
Not that i know of, it worked well. Sadly it is not under warranty.
由 [deleted] 完成的
So i tried to replace the antenna flex (with lightning port) and it didn't help. %#*@, I will probably have to buy a new one.
由 [deleted] 完成的
Have you tried backing up her data and completely resetting the phone to factory (erase all content and settings)? also did she recently update it? like to 8.4.1 or anything?
由 Gutseo 完成的
Yes I tried, she didn't upgrade to 8.4.1 yet.
由 [deleted] 完成的
