跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Back camera and back flash/LED not working (even after replacements)
I replaced the dock connector a few months ago and afterwards the back camera stopped working as did the flash/LED. The front camera is working fine as is the rest of the phone.
When I start the camera app the screen is black and the app crashes when trying to take a pic (other camera apps behave similarly). I can switch to the front facing camera in camera apps, but switching to the back camera again usually crashes the app. The backward facing flash/LED also is not working (e.g., when I turn on the flashlight app the button merely turns itself off again).
The back camera and LED didn't seem to be logically related hardware faults, but I did replace the flex cable (with the LED–no small feat!) and the back camera. Despite the fix, the faults with the back-facing camera and flash/LED persist (everything else is working fine.
Is this a problem with the board? I've tried hard restarts, but glad to try anything else that might come to mind :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It seems like there may be some components damaged or knocked off the board. I would look around the areas where the flex cables for the rear camera and flash connect to the board. You may need some sort of magnification so you can see better.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I'm going to cope without the camera for the time being, but I'll have a closer look next time I open it up.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 601
