跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
313 个问题 查看全部
top display is broken, where I can find a replacement?
The top display of my new nintendo 3ds xl is broken, and i cant find a replacement anywhere, also in my country nintendo doesnt have real presence so i can not send it to them for repair, so i need a replacement screen to do it by myself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论:
I was looking for the same thing. There is one thing you might want to consider. The NEW Nintendo 3DS XL (2015) has a slightly different screen than ones found on the original Nintendo 3DS XL. It uses IPS which allows for superior viewing angles. When you move your head from side to side to engage the face tracking 3D this helps with color reproduction. I could not find any screens that were positively for the NEW 3DS XL. Could you tell me how broken the screen is?
完成的
添加一条评论
4个答案
You can't find them at a regular store like Walmart or GameStop because that would be considered buying a "third party" item. If it's broken you'd could order it from E-bay, Ifixit.com or send it in for a repair.
这个答案有帮助吗?
得分 0
添加一条评论
I was looking for the same thing. There is one thing you might want to consider. The NEW Nintendo 3DS XL (2015) has a slightly different screen than ones found on the original Nintendo 3DS XL. It uses IPS which allows for superior viewing angles. When you move your head from side to side to engage the face tracking 3D this helps with color reproduction. I could not find any screens that were positively for the NEW 3DS XL. Could you tell me how broken the screen is? P.S Try checking amazon periodically, they have screens but they may not be the same ones.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue so i have the theory that we can use a regular 3ds xl upper screen but i dont know if thats true. The two parts look very similar and are of the same size but i dont know if anybody has tried this. If you try or have tried this please let me know the results.
这个答案有帮助吗?
得分 0
3条评论:
The older 3DS XL upper screen will not work in the *NEW 3DS XL.
It has a different ribbon connector for the 3D
完成的
Yes. if you can replace it with one of old 3ds xl
完成的
You cannot use the regular 3DS XL screen as a replacement for the New 3DS XL. The small ribbon cables that come off the side for the 3D slider are different. I have tried and it won't work.
完成的
添加一条评论
The only place I've been able to find a replacement is getting one on eBay that was pulled from another New (2015) 3DS XL. They are pricy, $50 used :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ANGEL GONZALEZ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,192
