跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Black screen and beeps when charging after battery replacement
Hi,
I know I'm not the first with this problem but I red all other questions and unfortunately nothing helped in my case...
So I replaced my iphone 5 battery with a new one (ordered on iFixit), and when I try to start the phone, nothing happens, the screen remains black.
Then I plugged it to a charger, and it started to beep (or vibrate in silence mode) every 10 seconds approximately.
Then I looked in ifixit for same problem, so I :
- checked all connector then reassemble the phone
- disassemble, disconnect and reconnect the battery, reassemble the phone (I tried it 3 or 4 times)
- try with the old battery
- try to clean each connector carefully
The phone is displayed in iTunes when plugged in and charging correctly.
The connectors don't seem to be damaged :
Do you think that I maybe damage something on the screen connector cables during my first opening ?
Indeed the screen came up a little roughly...
Is there any way check it ?
Thanks in advance
Steph
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
The first thing I would do is try a screen you know works, or at the very least a different screen. If that doesn't work, shine a flashlight at the screen and see if you can dimly make out the lock screen. Otherwise, post a photo of the connectors on the board with the black sticker removed.
这个答案有帮助吗?
得分 1
5条评论:
Unfortunately I don't have other iphone 5 screens to make this kind of test...
About the black sticker you talk about, is it the little one on the bottom left of my third photo ?
thanks
完成的
No, the one on the board where the screen connectors are.
完成的
I removed the black sticker. Here are the photos :
https://www.icloud.com/sharedalbum/#B0QG...
Thanks in advance
完成的
It looks like some of the chokes above the LCD connector are damaged, which would cause the issue you described. Those require microsoldering skills and equipment to replace. If you really cannot try another screen to rule out a defective one, or do not have the tools to replace the chokes, shoot me an email and I can help you out. My contact info is on my profile.
完成的
Finally the screen was the problem : with a new screen, it works well.
Thanks for your help
完成的
添加一条评论
Anytime I have had a blank screen with beeping every 10 seconds, it has always been a faulty LCD. I have seen it in both the iPad and iPhone and new LCD has resolved it every time.
这个答案有帮助吗?
得分 1
添加一条评论
How is the battery? Is it in any way damaged? (Small holes, cuts, etc)
I would probably put the phone in "recovery mode" and try that.
这个答案有帮助吗?
得分 0
3条评论:
The batteries are ok (the new one but also the old one).
And in iTunes, I can see that the battery is charging normally. So I don't think that there is a battery problem.
By the way, before my battery change, the phone screen worked perfectly fine.
In deed I could always try a recovery / restore..
Thx
完成的
I had a similar problem and I got it into recovery mode". Worked like a charm.
完成的
But it's hard to go in recovery mode as the screen isn't working.
I don't know how to turn the phone off without the screen, then I don't know when to release the home button (again without the screen)...
完成的
添加一条评论
添加你的答案
Steph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 6,030
