跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
问题已关闭
iPhone 5C screen not turning on after water damage and battery replace
So my grandpa dropped his iPhone 5C in some water and I had him turn it off and put in rice for a while.. The first attempt to turn on just got a slightly flickering apple logo and thats it. So I almost completely disassembled it and I tried cleaning it with some 91% iso alcohol. There was only a couple small areas of visible brownish corrosion like near the battery connector although the alcohol didn't seem to really remove it. I also replaced the battery. After this I have not been able to get the screen to come on. The phone itself is on because it makes a sound when plugging in a charger and registers in iTunes. It asks me to respond "trust" on the iPhone in order to access data in iTunes which I can not do without a functional display. It also will register if I put it in recovery mode. But I do not want to restore in recovery mode if possible so I do not lose all the data. Any ideas why the display won't come on? I have tried hard/soft resetting etc. I have tried reconnecting the display flex cables a few times. Is there any way to access the data on the iPhone and get it to backup in iTunes? I feel like I am so close to having it functioning again. Any help would be appreciated!
Update
Everything works except the screen is black. It responds to touch and Siri works! I just can't see anything
Does anyone know which flex cable is for the display and backlight?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
sounds like your screen might be dead. thats very common with water damaged devices. Ifixit has them available in their store.
这个答案有帮助吗?
得分 1
2条评论:
Hmm.. You think so even though it kind of turned on at first? That would be a bummer
完成的
So actually now it responds to touch and the home button and siri work! Everything except the screen is black. Any other ideas??
完成的
添加一条评论
It's possible that the display chip has some damage. You'd need to remove the EMI shields and clean the corrosion from there. If that does not work you could try reflowling the graphics chip. You'd need a hot air station ideally although a heat gun would work if you're careful.
这个答案有帮助吗?
得分 1
3条评论:
Oh okay Im fairly technically fluent but I have no idea what reflowing the graphics chip is
完成的
Pretty much, you use hot air to melt the solder joints in the hope that they reflow back in to position. This is usually a last resort if ultrasonic cleaning doesn't work.
完成的
yea i looked up reflow.. Makes sense. Would I target the whole logic board or just a specific chip or connector?
完成的
添加一条评论
If you try a known working screen and it is still black it could be the backlight. There are components on the board responsible for this and when a phone has water damage it can cause them to fail.
You then get the problem you describe where everything works okay but the screen is black.
这个答案有帮助吗?
得分 1
3条评论:
Do you think there's the potential of killing another display if I hook up a good one?
完成的
No you won't damage the display. If it is black like the other one you know it is most probably an issue with the backlight. Then you would just need to locate the faulty component or components and replace them.
完成的
Okay I think I will try to find another 5C that will so kindly lend me their screen haha
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 200
