跳转到主内容
A top-loading washing machine by Fisher&Paykel.
23 个问题 查看全部
How do I clean and repair the solenoid water valves?
I live in an area where the water has a high mineral content. The solenoid valves do not seat and leak. How do I access the valves? Can I dismantle and clean the valves? Are these valves a diaphragm or a spool valve? Can i fet parts or must the valve be replaced as a unit?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
the water valves are not very expensive - they may be available 2nd hand - try the scrappers
earlier machines may use identical parts
be very careful not to allow water to splash on or penetrate Motor Controller Panel etc
it could / will blow-up
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 1,416
