跳转到主内容
加入维修社区 - 创建账户
Repair guides for portable MP3 players, released first in 1997. These devices play back stored music from hard drives or flash memory.
My MP3 player won't turn on once I remove the charger.
I can listen to my Sylvania SMP2200 2GB MP3 Player when it is charging, but once it unplug it it stops and the light won't turn on. I know it has to be fully charged to play, but it was charging all night. Any tips?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 32
8条评论
I have the same problem with my bõrne 2GB MP3 player
完成的
I recently used my MP3 player like 2 minutes ago it was charging and then randomly stopped the screen is black but I know is on cause my mp3 light Botton turns on I can’t remove the back because has no way to remove the back please helppp me my MP3 player is mahai
完成的
I found just plugging it in for a little bit and fidgeting with the power button worked.
完成的
My Searick digital music player model: M6 had this problem. I kept pressed power button for almost 15/20 seconds and then it became semi functional. Then I turned off and ON again and voila its perfect now with battery showing 100% charge and music functional.
完成的
Woow! yes I did that and it worked! Thank youuuuuuuuuuuuuu!!!
完成的
显示更多的3条评论
添加一条评论
14个答案
已选择的解决方案
It sounds to me like you have a bad battery connection or a dead battery. Remove the back cover from the device. Locate the battery and its connector. DO NOT TOUCH THIS!!! It may be round or boxy. Using a spudger if you have one, otherwise use a pencil eraser, push the battery connector back in. Attempt to turn on the MP3 player. If this does not work, then you may have a dead battery.
这个答案有帮助吗?
得分 7
13条评论:
Do you think this could happen already? I just got it yesterday.
完成的
same thing happened to me. I haven't even used it yet.
完成的
Poor quality control (especially if from a "generic" brand) can pass products that don't work.
完成的
I just got mine.... is YES a generic brand?
完成的
My timikoo mp3 player was working fine but then it started to drain battery fast even while on charge so i turned it off to let it charge but when i woke up it was on 1% so i tried to get it to charge but then it turned of and the screen went black now it wont charge and will not turn on. PLZ HELP
完成的
显示更多的8条评论
添加一条评论
最有帮助的答案
I had this problem too its not the battery it must be switched on when charging but plug in your earphones and make sure no music is playing or the battery will be drained and it will result in no charging, That fixed mine hope it helps somebody :p :D
这个答案有帮助吗?
得分 8
10条评论:
Thanks! That worked for me! :D
完成的
I don't understand the steps. Can u explain in more detail? Please....
完成的
It did not work for me
完成的
I just got mine today let’s see if it works for me ^-^
完成的
Rachel I am trying the technique you suggested now, but how long do I keep it plugged up, cause the battery indicator displays the fully charged symbol but that's obviously not the case. Please reply ASAP. Thank you.
完成的
显示更多的5条评论
添加一条评论
Didn’t charge with the charger, but did so with a PC data connection; also the cable was VERY PICKY as to how much i inserted it into the player. Talking 1/10th of a mm. As soon as I got the data connection, it would charge, otherwise a (fake) charging screen. Hope that helps.
这个答案有帮助吗?
得分 3
添加一条评论
I have an answer that works on the MP3 players that you push a switch up to turn it on after you push it up the swith goes down, so my answer is for those MP3 players.
The answer: Hold the power switch up for about 15 seconds, that should make it turn on
这个答案有帮助吗?
得分 3
3条评论:
Thank you so much!!
完成的
it did not work
完成的
Thanks. It worked
完成的
添加一条评论
Either try a new charger or get the charging panel replaced.
这个答案有帮助吗?
得分 1
1条评论:
what is a charging panel?
完成的
添加一条评论
it sounds like its a case of dead(drained completely and cant be re-charged.) battery
这个答案有帮助吗?
得分 0
3条评论:
Can I use the charger in my wall socket to charge, or do I need to charge it from a computer? Some booklets suggest that, but some mp3 players will still charge without a computer. I don't have a computer anyway.
完成的
it dosent mader
完成的
I think that should be the problem 😕
完成的
添加一条评论
You could get a portable charger, if nothing already mentioned worked.
这个答案有帮助吗?
得分 0
1条评论:
My own charge but if i on it, it will show blue led light but it not sound if i first on it. what could be the problem?
完成的
添加一条评论
The batteries get old over time and will no longer hold a charge after a while. My best bet is unscrewing the inside and replacing the small battery in it. It should work fine after that.
这个答案有帮助吗?
得分 0
1条评论:
I have same problem mine wont charge, cant turn on... But I cant unscrew or anything else because it is completely made of metal body. Any help?
完成的
添加一条评论
hello , dont continiue
help me please .
这个答案有帮助吗?
得分 0
添加一条评论
mine only turns on when its charging i dont know what to do
这个答案有帮助吗?
得分 0
1条评论:
Mine charging but couldn't turn on even while charging
完成的
添加一条评论
i need help , so my mom just gave me a gogear phillips mp3 player and when its plugged up it flashes on and off with the phillips screen on it , and it wont do anything ive tried charging it for hours , what do i do?
这个答案有帮助吗?
得分 0
添加一条评论
I need help this is so hard to fix the problem with this new mp player
这个答案有帮助吗?
得分 0
1条评论:
When most mp3 manual says to charge by pc which is usb 5.0 volts, the wall usb 5.4 volts... I've had some brand new and it never came on sitting in pile to get to...
It's either control board or battery dead I figured when first got it used wall charger and overload the circuit wouldn't think it would be so significant but I've had problems with a few mp3 in my pile brand new...
完成的
添加一条评论
I need help on my mp3 led indicator both not blinking have changed it still the same pls solution
这个答案有帮助吗?
得分 0
添加一条评论
What I did was that was try buying a new charger and then take it to a repair shop and they are really cheap
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anchorsawaybyjulie78 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 67
过去 30 天: 260
总计 63,429
